RESOLU : Erreur rencontrées avec la 1.3
Charlie
lun. mars 17, 2014 10:06 am
Je viens d'installer la version 1.3 (j'étais en version 1.3b5) et j'ai lancé la mise à jour de la base via l'outil de configuration comme il est conseillé de le faire après une MAJ.
Lors du lancement d'OC je rencontre les deux erreurs suivantes :
Unable to create subscription list
java.lang.NoSuchMethodError: org.openconcerto.sql.model.graph.Path.add(Lorg/openconcerto/sql/model/SQLField;)Lorg/openconcerto/sql/model/graph/Path;
org.openconcerto.utils.ExceptionHandler: Unable to create subscription list
at org.openconcerto.modules.subscription.panel.AboPanel$4.done(AboPanel.java:153)
at org.openconcerto.utils.SwingWorker2$5.run(SwingWorker2.java:536)
at org.openconcerto.utils.SwingWorker2$DoSubmitAccumulativeRunnable.run(SwingWorker2.java:619)
at sun.swing.AccumulativeRunnable.run(AccumulativeRunnable.java:112)
at org.openconcerto.utils.SwingWorker2$DoSubmitAccumulativeRunnable.actionPerformed(SwingWorker2.java:631)
at javax.swing.Timer.fireActionPerformed(Timer.java:312)
at javax.swing.Timer$DoPostEvent.run(Timer.java:244)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:733)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:703)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154)
at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221)
at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219)
at java.awt.Dialog.show(Dialog.java:1082)
at java.awt.Component.show(Component.java:1651)
at java.awt.Component.setVisible(Component.java:1603)
at java.awt.Window.setVisible(Window.java:1014)
at java.awt.Dialog.setVisible(Dialog.java:1005)
at org.openconcerto.utils.ExceptionHandler.showMsg(ExceptionHandler.java:431)
at org.openconcerto.utils.ExceptionHandler.showMsgHardened(ExceptionHandler.java:188)
at org.openconcerto.utils.ExceptionHandler.display(ExceptionHandler.java:159)
at org.openconcerto.utils.ExceptionHandler.<init>(ExceptionHandler.java:460)
at org.openconcerto.erp.config.Gestion$2.uncaughtException(Gestion.java:194)
at java.awt.EventDispatchThread.processException(EventDispatchThread.java:264)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:256)
Caused by: java.util.concurrent.ExecutionException: java.lang.NoSuchMethodError: org.openconcerto.sql.model.graph.Path.add(Lorg/openconcerto/sql/model/SQLField;)Lorg/openconcerto/sql/model/graph/Path;
at java.util.concurrent.FutureTask.get(FutureTask.java:188)
at org.openconcerto.utils.SwingWorker2.get(SwingWorker2.java:412)
at org.openconcerto.modules.subscription.panel.AboPanel$4.done(AboPanel.java:140)
... 42 more
Caused by: java.lang.NoSuchMethodError: org.openconcerto.sql.model.graph.Path.add(Lorg/openconcerto/sql/model/SQLField;)Lorg/openconcerto/sql/model/graph/Path;
at org.openconcerto.modules.project.Module$2.getPaths(Module.java:205)
at org.openconcerto.sql.view.list.SQLTableModelSourceOnline.colsChanged(SQLTableModelSourceOnline.java:51)
at org.openconcerto.sql.view.list.SQLTableModelSource$3.executeChecked(SQLTableModelSource.java:148)
at org.openconcerto.sql.view.list.SQLTableModelSource$3.executeChecked(SQLTableModelSource.java:1)
at org.openconcerto.utils.change.ListChangeRecipe.add(ListChangeRecipe.java:104)
at org.openconcerto.utils.change.ListChangeRecipe.add(ListChangeRecipe.java:108)
at org.openconcerto.utils.change.ListChangeRecorder.addAll(ListChangeRecorder.java:117)
at org.openconcerto.sql.element.SQLElement.createAndInitTableSource(SQLElement.java:1091)
at org.openconcerto.sql.element.SQLElement.getTableSource(SQLElement.java:1076)
at org.openconcerto.modules.subscription.panel.AboPanel$4.doInBackground(AboPanel.java:130)
at org.openconcerto.modules.subscription.panel.AboPanel$4.doInBackground(AboPanel.java:1)
at org.openconcerto.utils.SwingWorker2$1.call(SwingWorker2.java:115)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at org.openconcerto.utils.SwingWorker2.run(SwingWorker2.java:163)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:744)
org.openconcerto.sql.model.graph.Path.addForeignField(Ljava/lang/String;)Lorg/openconcerto/sql/model/graph/Path;
Caused by: java.lang.NoSuchMethodError: org.openconcerto.sql.model.graph.Path.addForeignField(Ljava/lang/String;)Lorg/openconcerto/sql/model/graph/Path;
at org.openconcerto.modules.project.Module.createQuotePanel(Module.java:451)
at org.openconcerto.modules.project.Module.start(Module.java:413)
at org.openconcerto.erp.modules.ModuleManager.startModule(ModuleManager.java:1744)
at org.openconcerto.erp.modules.ModuleManager.access$2(ModuleManager.java:1741)
at org.openconcerto.erp.modules.ModuleManager$9.run(ModuleManager.java:1667)
... 5 more
Une petite idée sur l'origine du problème et surtout comment y remédier ?
À noter que malgré ces erreurs le logiciels se lance correctement, la saisie (client, devis, ...) semble fonctionner (pas de messages d'erreur), par contre la relecture non : impossible de consulter la liste des devis faits.
Modifié en dernier par Charlie le lun. mars 17, 2014 1:39 pm, modifié 1 fois.
lun. mars 17, 2014 10:30 am
modules pas à jour!
Charlie
Tout simplement.
