Erreur à saisie d'un achat fournisseur
studio nigao
jeu. févr. 13, 2014 4:23 pm
Cette fois-ci je viens vers vous, car je tente de saisir un achat fournisseur.
Dès que je cliques sur le bouton j'ai un code d'erreur qui est généré
	at org.openconcerto.erp.config.Gestion$1.uncaughtException(Gestion.java:117)
	at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:981)
	at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:976)
	at apple.awt.CToolkit$EventQueueExceptionHandler.handle(CToolkit.java:81)
	at java.awt.EventDispatchThread.handleException(EventDispatchThread.java:412)
	at java.awt.EventDispatchThread.processException(EventDispatchThread.java:318)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:312)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
	at org.openconcerto.erp.core.common.ui.MontantPanel.calculMontant(MontantPanel.java:218)
	at org.openconcerto.erp.core.common.ui.MontantPanel$4.propertyChange(MontantPanel.java:142)
	at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:339)
	at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:276)
	at org.openconcerto.ui.valuewrapper.ValueChangeSupport.fireValueChange(ValueChangeSupport.java:56)
	at org.openconcerto.sql.sqlobject.SQLRequestComboBox.comboValueChanged(SQLRequestComboBox.java:397)
	at org.openconcerto.sql.sqlobject.SQLRequestComboBox.access$6(SQLRequestComboBox.java:395)
	at org.openconcerto.sql.sqlobject.SQLRequestComboBox$7.propertyChange(SQLRequestComboBox.java:238)
	at org.openconcerto.ui.component.combo.ISearchableCombo.selectionChanged(ISearchableCombo.java:735)
	at org.openconcerto.ui.component.combo.ISearchableCombo$1.contentsChanged(ISearchableCombo.java:208)
	at javax.swing.AbstractListModel.fireContentsChanged(AbstractListModel.java:100)
	at org.openconcerto.utils.model.DefaultIMutableListModel.setSelectedItem(DefaultIMutableListModel.java:74)
	at org.openconcerto.ui.component.combo.ISearchableCombo.setSelection(ISearchableCombo.java:718)
	at org.openconcerto.ui.component.combo.ISearchableCombo.setComboItemValue(ISearchableCombo.java:706)
	at org.openconcerto.ui.component.combo.ISearchableCombo.setValue(ISearchableCombo.java:688)
	at org.openconcerto.ui.component.combo.ISearchableCombo.setValue(ISearchableCombo.java:642)
	at org.openconcerto.sql.sqlobject.SQLRequestComboBox.modelValueChanged(SQLRequestComboBox.java:392)
	at org.openconcerto.sql.sqlobject.SQLRequestComboBox.access$3(SQLRequestComboBox.java:387)
	at org.openconcerto.sql.sqlobject.SQLRequestComboBox$3.propertyChange(SQLRequestComboBox.java:186)
	at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:347)
	at org.openconcerto.sql.sqlobject.IComboModel.comboValueChanged(IComboModel.java:491)
	at org.openconcerto.sql.sqlobject.IComboModel.access$2(IComboModel.java:490)
	at org.openconcerto.sql.sqlobject.IComboModel$2.contentsChanged(IComboModel.java:165)
	at org.openconcerto.sql.sqlobject.IComboModel.selectID(IComboModel.java:549)
	at org.openconcerto.sql.sqlobject.IComboModel.access$14(IComboModel.java:495)
	at org.openconcerto.sql.sqlobject.IComboModel$4.done(IComboModel.java:339)
	at org.openconcerto.utils.SwingWorker2$5.run(SwingWorker2.java:536)
	at org.openconcerto.utils.SwingWorker2$DoSubmitAccumulativeRunnable.run(SwingWorker2.java:619)
	at sun.swing.AccumulativeRunnable.run(AccumulativeRunnable.java:95)
	at org.openconcerto.utils.SwingWorker2$DoSubmitAccumulativeRunnable.actionPerformed(SwingWorker2.java:631)
	at javax.swing.Timer.fireActionPerformed(Timer.java:291)
	at javax.swing.Timer$DoPostEvent.run(Timer.java:221)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:715)
	at java.awt.EventQueue.access$400(EventQueue.java:82)
	at java.awt.EventQueue$2.run(EventQueue.java:676)
	at java.awt.EventQueue$2.run(EventQueue.java:674)
	at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:86)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:685)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
	... 5 more
Malgré cela j'arrive sur la fenêtre d'achats mais il m'est impossible de finaliser la saisie.
Le champs "numéro de compte de charge" n'a pas de liste déroulante, je ne peux pas y entrer manuellement les infos.
Le bouton "selection compte" me donne la liste des comptes dans un pop up, mais je ne peux pas ramener d'éléments dans le champs principal.
Ma configuration : OpenConcerto 1.2 Monoposte / Mac OSX / Base H2
Bien cordialement.
Ps : étant à l'ile de la Réunion, notre taux de TVA normal est à 8.5% et le réduit à 2.10%.
Dans les préférences de OpenConcerto, j'ai donc enlever la TVA à 19.6%.
Cela semble généré des erreur au chargement (Erreur taxe(2) archivée)
