Problème avec extension
Charlie
mer. janv. 15, 2014 2:41 pm
Boujour,
Je m'essaye à la création d'extension avec le module builder et lorsque j'essaye ma première extension j'ai ce message d'erreur :
at org.openconcerto.erp.config.Gestion$2.uncaughtException(Gestion.java:188)
at java.awt.EventDispatchThread.processException(EventDispatchThread.java:264)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:256)
at org.openconcerto.modules.extensionbuilder.Extension$1.createFrame(Extension.java:174)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.Component.processMouseEvent(Component.java:6505)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3311)
at java.awt.Component.processEvent(Component.java:6270)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:708)
at java.awt.EventQueue$4.run(EventQueue.java:706)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:705)
... 5 more
Est-ce que j'ai loupé une étape.
D'avance merci
Charlie
mer. janv. 15, 2014 4:54 pm
Cela vient d'un menu ajouté pour créer un nouveau composant.
Le système ne trouve pas le composant associé au menu.
La mise à jour du module (même url) vous donnera le nom de l'identifiant manquant.
Nous avons pas encore tout "blindé", par contre si vous voulez faire avancer la gestion de tous les cas (tordus ou pas)
vous pouvez partager votre extension en pièce jointe pour que nous y regardions.
L'idée avec les extensions c'est qu'elles soient facilement partageables entre utilisateurs.
N'hésitez pas à partager.
Charlie
mer. janv. 15, 2014 10:39 pm
J'ai essayé de la mettre en PJ mais l'extension a été refusée.
Par contre j'avais pas pensé à l'archiver :mrgreen: .
Concernant l'extension, c'est du très basique... c'était juste pour faire un test avant de rentrer dans le dur.
Je la mets en PJ et le message d'erreur associé (j'ai du la refaire, donc au cas où ...)
No ComponentDescritor for null
Caused by: java.lang.IllegalStateException: No ComponentDescritor for null
at org.openconcerto.modules.extensionbuilder.Extension$1.createFrame(Extension.java:175)
... 5 more
Par contre on le voit où le nom de l'identifiant manquant ?
extension 1.ocext.tar.gz
(773 Octets) Téléchargé 488 fois
ven. janv. 17, 2014 5:07 pm
Merci Charlie!
La mise à jour du module Extension Builder corrige le problème:
Voir http://openconcerto.org/fr/telechargement/betas/1.3b5/
Le forum accepte désormais les extensions non zippées.
elpinfo
lun. janv. 20, 2014 7:27 am
Je viens d'essayer le module extension, mais je rencontre un soucis un peu génant pour l'organisation: je n'arrive pas a renommer le nom des champs, ils reviennent sytematiquement en field1,field2,etc.... et les longueur reviennent a 200. Bref ça n'enregistre pas
version openconcerto 3b5 et dernier module en date.
y'a t'il quelque chose que j'ai loupé?
merci par avance
Elsa
mar. janv. 21, 2014 6:23 pm
nouvelle version disponible du Module Extension Builder!
Devrait mieux fonctionner désormais dans votre cas.
elpinfo
mer. janv. 22, 2014 8:19 am
Ce bug est corrigé merci mais il y a toujours le soucis du champs reference .
quand je prends l'exemple du manuel dans le menu déroulant je ne vois pas la table projet ce qui est génant pour la suite de l'extension.
par exemple lorsque je veux visualiser l'interface de saisie il me dit qu'il n'y a pas de table
de plus lorsque je quitte openconcerto et que je le relance tout mon travail a disparu :twisted:
cdt
Elsa
jeu. janv. 23, 2014 2:24 pm
pour l'instant, pour voir la table, il faut enregistrer et redémarrer l'extension.
