problème ouverture application OpenConcerto Caisse
julienbz
lun. mars 18, 2013 11:32 pm
Nouvel utilisateur d'OpenConcerto je n'arrive pas à accéder à Caisse OpenConcerto.
Voici le message d'erreur qui s'affiche quand je double-clique sur l'icône :
Impossible de lire le fichier de configuration.
found neither /Users/Julien/Library/Preferences/OpenConcerto/main.properties nor embedded main.properties
org.openconcerto.utils.ExceptionHandler: Impossible de lire le fichier de configuration.
at org.openconcerto.utils.ExceptionHandler.die(ExceptionHandler.java:106)
at org.openconcerto.erp.config.ComptaPropsConfiguration.create(ComptaPropsConfiguration.java:313)
at org.openconcerto.erp.config.ComptaPropsConfiguration.create(ComptaPropsConfiguration.java:283)
at org.openconcerto.erp.config.ComptaPropsConfiguration.create(ComptaPropsConfiguration.java:279)
at org.openconcerto.erp.core.sales.pos.Caisse.createConnexion(Caisse.java:114)
at org.openconcerto.erp.core.sales.pos.ui.CaisseFrame$1.run(CaisseFrame.java:89)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:708)
at java.awt.EventQueue.access$400(EventQueue.java:82)
at java.awt.EventQueue$2.run(EventQueue.java:669)
at java.awt.EventQueue$2.run(EventQueue.java:667)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:678)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
Caused by: java.io.IOException: found neither /Users/Julien/Library/Preferences/OpenConcerto/main.properties nor embedded main.properties
at org.openconcerto.erp.config.ComptaPropsConfiguration.create(ComptaPropsConfiguration.java:308)
... 18 more
Je suis sous Mac OS X 10.6.8 et je viens de mettre à jour Java.
Pouvez-vous m'aider à régler ce problème ?
Un grand merci d'avance !
sam. mars 30, 2013 11:52 am
Pour lancer la caisse, il faut la configurer préalablement avec l'outil de Configuration.
Cependant, un bug de l'outil de Configuration en version 1.2 ne va pas vous faciliter la tâche.
Passez en version 1.3b2.
