PB D OUVERTURE OC
NDE-BB
mer. oct. 02, 2019 10:09 am
en voulant afficehr un doc, l'ordi c'est éteint et nous avons ce message qui s'affiche ?????
impossible de le rouvrir ?
java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:postgresql://127.0.0.1:5432/OpenConcerto
at org.openconcerto.utils.ExceptionHandler.handle(ExceptionHandler.java:135)
at org.openconcerto.utils.ExceptionHandler.handle(ExceptionHandler.java:140)
at org.openconcerto.erp.config.Gestion$2.uncaughtException(Gestion.java:205)
Caused by: java.lang.IllegalStateException: java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:postgresql://127.0.0.1:5432/OpenConcerto
at org.openconcerto.sql.PropsConfiguration$Addable.get(PropsConfiguration.java:1156)
at org.openconcerto.sql.PropsConfiguration.getDirectory(PropsConfiguration.java:1340)
at org.openconcerto.erp.config.Gestion.main(Gestion.java:328)
Caused by: java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:postgresql://127.0.0.1:5432/OpenConcerto
at org.openconcerto.sql.PropsConfiguration$Addable.get(PropsConfiguration.java:1152)
... 2 more
Caused by: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:postgresql://127.0.0.1:5432/OpenConcerto
at org.openconcerto.sql.PropsConfiguration.createSystemRoot(PropsConfiguration.java:739)
at org.openconcerto.erp.config.ComptaPropsConfiguration.createSystemRoot(ComptaPropsConfiguration.java:779)
at org.openconcerto.sql.PropsConfiguration.getSystemRoot(PropsConfiguration.java:1220)
at org.openconcerto.sql.PropsConfiguration.createRoot(PropsConfiguration.java:433)
at org.openconcerto.sql.PropsConfiguration.getRoot(PropsConfiguration.java:1196)
at org.openconcerto.sql.element.ConfSQLElement.<init>(ConfSQLElement.java:45)
at org.openconcerto.sql.element.ConfSQLElement.<init>(ConfSQLElement.java:41)
at org.openconcerto.sql.element.ConfSQLElement.<init>(ConfSQLElement.java:37)
at org.openconcerto.task.config.ComptaBasePropsConfiguration.createDirectory(ComptaBasePropsConfiguration.java:146)
at org.openconcerto.erp.config.ComptaPropsConfiguration.createDirectory(ComptaPropsConfiguration.java:795)
at org.openconcerto.sql.PropsConfiguration$1.create(PropsConfiguration.java:258)
at org.openconcerto.sql.PropsConfiguration$Addable$1.call(PropsConfiguration.java:1132)
at org.openconcerto.sql.PropsConfiguration$Addable.get(PropsConfiguration.java:1150)
... 2 more
Caused by: org.postgresql.util.PSQLException: FATAL: le système de bases de données se lance (pgjdbc: autodetected server-encoding to be ISO-8859-1, if the message is not readable, please check database logs and/or host, port, dbname, user, password, pg_hba.conf)
at org.postgresql.Driver$ConnectThread.getResult(Driver.java:403)
at org.postgresql.Driver.connect(Driver.java:261)
... 33 more
JacquesF
mer. oct. 02, 2019 10:25 am
À priori, l'installation est faite avec un serveur PostgreSQL en local sur le PC d'après le premier message d'erreur :
Si c'est bien le cas, il faut vérifier que le serveur PostgreSQL est bien actif (panneau de configuration, administration, services).
Si c'est une installation en mode autonome (base de données H2), alors il serait bien de relancer l'application de configuration dans le menu démarrer/OpenConcerto pour vérifier les paramètres d'accès à la base de données.
Je ne vois pas d'autre piste pour le moment.
Jacques
NDE-BB
mer. oct. 02, 2019 11:19 am
merci Jacques,
je vois ça avec notre spécialiste informatique dès qu'il sera là.
manque de pot il est absent pour le moment.
mer. oct. 02, 2019 1:26 pm
Voila pourquoi avoir un serveur est fortement conseillé.
