Installation Modules.
Provaire
dim. juin 03, 2018 12:01 pm
Bonjour, je persiste et signe.
J'ai réussi a faire fonctionner les modules en mettant Java8 dans opt et en modifiant .profile (rajout de PATH="/opt/jre1.8.0_161/bin:$HOME/bin:$PATH") Merci au Forum Ubuntu
OpenConcerto fonctionne très bien, mais a l'installation des modules j'ai une erreur JAVA ?
/home/eric/.java/.userPrefs/org/openconcerto/erp/modules/_!'4!|w!n!'g!:g==/_!'4!|w!n!'}!a@"s!'`!,w"$!#c!`w"o!'8!b@"l!#c!`w"l!()!a@"j!#c!`w!u!'w!bw"j!'%!b!!n!&:!cw"o!'%!cg"l!#c!`w">!(!!~@"u!%:!bw"u!':!~@"y!(@!bw!n!&:![!"#!%@!}@"0!'%!,w"^/_!'4!|w!n!%8!c!"l!'4!@w"v!'4!}w"l!()!d!"v/_!'4!|w!n!%8!c!"l!'4!@w"v!'4!}w"l!()!d!"v!$@!<!==/toRun create failed.
org.openconcerto.utils.ExceptionHandler: Impossible d'activer les modules
	at org.openconcerto.erp.modules.ModulePanel$StartStopAction.actionPerformed(ModulePanel.java:375)
	at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
	at java.awt.Container.processEvent(Container.java:2238)
	at java.awt.Container.dispatchEventImpl(Container.java:2296)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4897)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4534)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4475)
	at java.awt.Container.dispatchEventImpl(Container.java:2282)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
	at java.awt.EventQueue$4.run(EventQueue.java:733)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
Caused by: java.util.prefs.BackingStoreException: /home/eric/.java/.userPrefs/org/openconcerto/erp/modules/_!'4!|w!n!'g!:g==/_!'4!|w!n!'}!a@"s!'`!,w"$!#c!`w"o!'8!b@"l!#c!`w"l!()!a@"j!#c!`w!u!'w!bw"j!'%!b!!n!&:!cw"o!'%!cg"l!#c!`w">!(!!~@"u!%:!bw"u!':!~@"y!(@!bw!n!&:![!"#!%@!}@"0!'%!,w"^/_!'4!|w!n!%8!c!"l!'4!@w"v!'4!}w"l!()!d!"v/_!'4!|w!n!%8!c!"l!'4!@w"v!'4!}w"l!()!d!"v!$@!<!==/toRun create failed.
	at java.util.prefs.FileSystemPreferences$7.run(FileSystemPreferences.java:619)
	at java.util.prefs.FileSystemPreferences$7.run(FileSystemPreferences.java:615)
	at java.util.prefs.FileSystemPreferences.writeBackCache(FileSystemPreferences.java:614)
	at java.util.prefs.FileSystemPreferences.syncSpiPrivileged(FileSystemPreferences.java:801)
	at java.util.prefs.FileSystemPreferences.access$2300(FileSystemPreferences.java:50)
	at java.util.prefs.FileSystemPreferences$12.run(FileSystemPreferences.java:771)
	at java.util.prefs.FileSystemPreferences$12.run(FileSystemPreferences.java:769)
	at java.util.prefs.FileSystemPreferences.syncSpi(FileSystemPreferences.java:768)
	at java.util.prefs.AbstractPreferences.sync2(AbstractPreferences.java:1338)
	at java.util.prefs.AbstractPreferences.sync(AbstractPreferences.java:1329)
	at java.util.prefs.FileSystemPreferences.sync(FileSystemPreferences.java:747)
	at java.util.prefs.FileSystemPreferences.flush(FileSystemPreferences.java:824)
	at org.openconcerto.erp.modules.ModuleManager.putRefs(ModuleManager.java:1257)
	at org.openconcerto.erp.modules.ModuleManager.setPersistentModules(ModuleManager.java:1333)
	at org.openconcerto.erp.modules.ModuleManager.applyChange(ModuleManager.java:1623)
	at org.openconcerto.erp.modules.ModuleManager.createModules(ModuleManager.java:1467)
	at org.openconcerto.erp.modules.ModuleManager.startModules(ModuleManager.java:1308)
	at org.openconcerto.erp.modules.ModulePanel$StartStopAction.actionPerformed(ModulePanel.java:353)
	... 37 more
Le module s'active mais au redémarrage d'OpenConcerto je suis obligé de recommencer?
Je suis sous UBUNTU16.04 Java8.
Je confirme que sous Windows10 et 7 OpenConcerto ne rencontre pas ce problème.
Je pense que je me suis planté mais ou?
lun. juin 04, 2018 12:49 pm
Ce problème est lié à votre utilisation de ecryptfs (dossier personnel crypté) qui a pour effet de bord de limiter la longueur des noms des fichiers par 2.
Provaire
lun. juin 04, 2018 6:49 pm
Bonjour, merci pour votre explication.
Je commençais sérieusement a penser que j'avais une mauvaise installation de Ubuntu.
Je vais voir du côté de Ubuntu si on peut trouver une astuce.
mar. juin 05, 2018 12:57 pm
Provaire
mar. juin 05, 2018 7:41 pm
Bonjour, merci pour l'information.
Je vais voir si Ubuntu a une solution pour le Bug sinon je changerai de Linux (il va falloir que je perde mes mauvaises habitudes). Si a tout hasard vous connaissez des versions cryptés compatible, je suis preneur.
En vous remerciant.
mar. juin 05, 2018 8:36 pm
Pour ma part, je suis sous Mageia 6. Mon /home est chiffré avec dm-crypt apparemment. Je n'utilise pas de modules actuellement, mais j'en avais installé temporairement deux pour voir, et ils ont fonctionné.
mer. juin 06, 2018 11:15 am
Ubuntu est un bon choix, il suffit de ne pas activer l'option de chiffrement.
dm-crypt n'a pas la limitation de longueur de ecryptfs.
Voici comment procéder avec Ubuntu si vous voulez chiffrer sans avoir de bugs génants (OpenConcerto ou autres) :
https://doc.ubuntu-fr.org/tutoriel/chiffrer_son_disque
Provaire
sam. juin 09, 2018 8:44 am
Bonjour, merci a tous pour réponses.
Je vais tester la version 18.04 de Ubuntu avant de franchir le pat sur OpenConcerto.
Depuis la Version 17.10 de Ubuntu le problème de bug de ecryptfs semblerai réglé.
Bien Cordialement
