CAISSE - Ne se lance pas [RESOLU]
dim. oct. 16, 2011 12:45 pm
Sur un installation neuve -- versions d'après 14h ce dimanche. Postgre 9.1 nouvellement installé.
OpenConcerto Fonctionne
Caisse créée
Mais quand je lance la caisse en ligne de commande, j'obtiens :
panhamac@upstairs:~/OpenConcerto-1.1-multiposte$ ./OpenConcerto-Caisse.sh
Lancement du module de caisse
Loading:/home/panhamac/OpenConcerto-1.1-multiposte/./Configuration/pos.xml
Module directory doesn't exist : C:\Program Files\EPSON\JavaPOS\lib11
Loading configuration from:/home/panhamac/.OpenConcerto/main.properties
Log directory: /home/panhamac/OpenConcerto/logs/upstairs-panhamac
Log file: /home/panhamac/OpenConcerto/logs/upstairs-panhamac/OpenConcerto_2011-10/16_dimanche.txt
et, bien sur, pas de caisse!
Voici le log après lancement de la caisse.
Logger logs: /home/panhamac/OpenConcerto/Logs/upstairs-panhamac/OpenConcerto-%u-age%g.log
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: org/openconcerto/erp/generationDoc/element/TypeModeleSQLElement
	at org.openconcerto.erp.config.ComptaPropsConfiguration.createDirectory(ComptaPropsConfiguration.java:437)
	at org.openconcerto.sql.PropsConfiguration.getDirectory(PropsConfiguration.java:784)
	at org.openconcerto.erp.config.ComptaPropsConfiguration.setSocieteDirectory(ComptaPropsConfiguration.java:443)
	at org.openconcerto.erp.config.ComptaPropsConfiguration.setUpSocieteDataBaseConnexion(ComptaPropsConfiguration.java:724)
	at org.openconcerto.erp.core.sales.pos.Caisse.createConnexion(Caisse.java:127)
	at org.openconcerto.erp.core.sales.pos.ui.CaisseFrame$1.run(CaisseFrame.java:78)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:641)
	at java.awt.EventQueue$1.run(EventQueue.java:602)
	at java.awt.EventQueue$1.run(EventQueue.java:600)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:611)
Caused by: java.lang.ClassNotFoundException: org.openconcerto.erp.generationDoc.element.TypeModeleSQLElement
	at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
	... 20 more
Mon main.properties :
#OpenConcerto
#Sun Oct 16 13:43:38 CEST 2011
systemRoot=OpenConcerto
server.ip=127.0.0.1\:5432
customer=Gestion_Default
server.driver=postgresql
Ma config : Ubuntu 10.10, Java 1.6.0_26-b03, PostGreSQL 9.1
Qui sait?
Modifié en dernier par xantof le dim. oct. 16, 2011 3:23 pm, modifié 1 fois.
dim. oct. 16, 2011 2:16 pm
Il y eu un petit méli-mélo lors de l'upload du correctif de dernière minute hier soir.
Le problème de caisse est corrigé, il vous suffit de re-télécharger le logiciel.
dim. oct. 16, 2011 3:27 pm
Merci Guillaume !
Tout semble marcher suite à l'installation globale par le biais du script. [sur Ubuntu 11.04 en tout cas]
