je viens d'installer OpenConcerto sur mon mac et je ne peux pas modifier les modèles (facture, devis, est...).
Voici le message d'erreur :
UncaughtException on thread Thread[AWT-EventQueue-0,6,main] Copie impossible org.openconcerto.utils.ExceptionHandler: UncaughtException on thread Thread[AWT-EventQueue-0,6,main] at org.openconcerto.utils.ExceptionHandler.handle(ExceptionHandler.java:129) at org.openconcerto.utils.ExceptionHandler.handle(ExceptionHandler.java:134) at org.openconcerto.erp.config.Gestion$2.uncaughtException(Gestion.java:201) at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:1057) at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:1052) at java.awt.EventDispatchThread.processException(EventDispatchThread.java:223) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:215) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) Caused by: java.lang.IllegalStateException: Copie impossible at org.openconcerto.erp.generationDoc.DefaultLocalTemplateProvider.unSync(DefaultLocalTemplateProvider.java:116) at org.openconcerto.erp.preferences.TemplateTableModel.unsync(TemplateTableModel.java:78) at org.openconcerto.erp.preferences.TemplatePreferencePanel.modifyTemplateXML(TemplatePreferencePanel.java:356) at org.openconcerto.erp.preferences.TemplatePreferencePanel$2$2.actionPerformed(TemplatePreferencePanel.java:154) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.AbstractButton.doClick(AbstractButton.java:376) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833) at com.apple.laf.AquaMenuItemUI.doClick(AquaMenuItemUI.java:157) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877) at java.awt.Component.processMouseEvent(Component.java:6533) at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) at java.awt.Component.processEvent(Component.java:6298) at java.awt.Container.processEvent(Container.java:2236) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2294) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466) at java.awt.Container.dispatchEventImpl(Container.java:2280) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.awt.EventQueue$4.run(EventQueue.java:729) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80) at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) ... 5 more Caused by: java.io.FileNotFoundException: ../../../../../../../../../../../../Users/michelantoni/Documents/OpenConcerto/Web Dream-49/local_VenteFacture.ods (Read-only file system) at java.io.FileOutputStream.open0(Native Method) at java.io.FileOutputStream.open(FileOutputStream.java:270) at java.io.FileOutputStream.(FileOutputStream.java:213) at java.io.FileOutputStream.(FileOutputStream.java:162) at org.openconcerto.utils.FileUtils.copyFile(FileUtils.java:409) at org.openconcerto.utils.FileUtils.copyFile(FileUtils.java:393) at org.openconcerto.erp.generationDoc.DefaultLocalTemplateProvider.unSync(DefaultLocalTemplateProvider.java:113) ... 42 more
Pouvez-vous m'aider ?
						Impossible de modifier un modèle
encore et toujours MacOs qui fait des siennes avec des permissions étranges...
Cette partie est en lecture seule apparemment.
La semaine dernière, sur ce même forum...
viewtopic.php?f=9&t=2187&p=9189&hilit=macos#p9189
Donc :
- désactiver iCloud sur ce dossier
- Paramétrer les permissions
- éditer directement les modèles sans passer par le logiciel
Je donne ici des pistes basés sur les expériences des précédents utilisateurs, car je ne suis pas utilisateur de Mac
Code : Tout sélectionner
Caused by: java.io.FileNotFoundException: ../../../../../../../../../../../../Users/michelantoni/Documents/OpenConcerto/Web Dream-49/local_VenteFacture.ods (Read-only file system)La semaine dernière, sur ce même forum...
Donc :
HDDR49.fr
HDDR49.fr
