Bug sur table fournisseurs
mar. janv. 09, 2018 3:51 pm
Je remonte juste un petit bug mais assez gênant qui empêche la modification ou l'ajout d'un fournisseur.
Je suis sur la version 1.5.1 (j'ai bien fait la mise à jour de la base de donnée à l'install ;) ).
Erreur d'initialisation
unknown field ID_CATEGORIE_COMPTABLE in FOURNISSEUR. The table FOURNISSEUR contains the followins fields: [ID_FOURNISSEUR, TYPE, NOM, CODE, ID_ADRESSE, ID_ADRESSE_E, ARCHIVE, ORDRE, UE, ID_COMPTE_PCE, ID_MODE_REGLEMENT, TEL, FAX, MODIFICATION_DATE, ID_USER_COMMON_MODIFY, ID_USER_COMMON_CREATE, CREATION_DATE, ID_LANGUE, ID_DEVISE, RESPONSABLE, TEL_P, MAIL, INFOS, ID_COMPTE_PCE_CHARGE, ATTACHMENTS, NUMERO_TVA, SIRET]
	at org.openconcerto.sql.view.EditPanel.<init>(EditPanel.java:211)
	at org.openconcerto.sql.view.EditPanel.<init>(EditPanel.java:141)
	at org.openconcerto.sql.view.IListPanel.getCreateFrame(IListPanel.java:607)
	at org.openconcerto.sql.view.IListPanel.handleAction(IListPanel.java:519)
	at org.openconcerto.sql.view.ListeAddPanel.handleAction(ListeAddPanel.java:65)
	at org.openconcerto.sql.view.IListPanel.actionPerformed(IListPanel.java:468)
Caused by: java.lang.IllegalArgumentException: unknown field ID_CATEGORIE_COMPTABLE in FOURNISSEUR. The table FOURNISSEUR contains the followins fields: [ID_FOURNISSEUR, TYPE, NOM, CODE, ID_ADRESSE, ID_ADRESSE_E, ARCHIVE, ORDRE, UE, ID_COMPTE_PCE, ID_MODE_REGLEMENT, TEL, FAX, MODIFICATION_DATE, ID_USER_COMMON_MODIFY, ID_USER_COMMON_CREATE, CREATION_DATE, ID_LANGUE, ID_DEVISE, RESPONSABLE, TEL_P, MAIL, INFOS, ID_COMPTE_PCE_CHARGE, ATTACHMENTS, NUMERO_TVA, SIRET]
	at org.openconcerto.sql.model.SQLTable.getField(SQLTable.java:953)
	at org.openconcerto.sql.element.BaseSQLComponent.getField(BaseSQLComponent.java:175)
	at org.openconcerto.sql.element.BaseSQLComponent.addView(BaseSQLComponent.java:275)
	at org.openconcerto.sql.element.BaseSQLComponent.addView(BaseSQLComponent.java:267)
	at org.openconcerto.erp.core.supplychain.supplier.component.FournisseurSQLComponent.addViews(FournisseurSQLComponent.java:390)
	at org.openconcerto.sql.element.SQLComponent.uiInit(SQLComponent.java:209)
	at org.openconcerto.sql.view.EditPanel.<init>(EditPanel.java:204)
	... 43 more
mar. janv. 09, 2018 4:32 pm
C'est un bug qui a été corrigé lors de la release. Re-téléchargez!
mar. janv. 09, 2018 5:44 pm
Effectivement, problème réglé.
