erreur création fournisseur[RESOLU]
lodnexus
jeu. janv. 04, 2018 11:11 am
je me retrouve face à une erreur lorsque que j'essai de créer un fournisseur via la liste fournisseur.
Erreur d'initialisation
unknown field ID_CATEGORIE_COMPTABLE in FOURNISSEUR. The table FOURNISSEUR contains the followins fields: [ID_FOURNISSEUR, TYPE, NOM, CODE, ID_ADRESSE, ID_ADRESSE_E, ARCHIVE, ORDRE, UE, ID_COMPTE_PCE, ID_MODE_REGLEMENT, TEL, FAX, MODIFICATION_DATE, ID_USER_COMMON_MODIFY, ID_USER_COMMON_CREATE, CREATION_DATE, ID_LANGUE, ID_DEVISE, RESPONSABLE, TEL_P, MAIL, INFOS, ID_COMPTE_PCE_CHARGE, ATTACHMENTS, NUMERO_TVA, SIRET]
	at org.openconcerto.sql.view.EditPanel.<init>(EditPanel.java:211)
	at org.openconcerto.sql.view.EditPanel.<init>(EditPanel.java:141)
	at org.openconcerto.sql.view.IListPanel.getCreateFrame(IListPanel.java:607)
	at org.openconcerto.sql.view.IListPanel.handleAction(IListPanel.java:519)
	at org.openconcerto.sql.view.ListeAddPanel.handleAction(ListeAddPanel.java:65)
	at org.openconcerto.sql.view.IListPanel.actionPerformed(IListPanel.java:468)
Caused by: java.lang.IllegalArgumentException: unknown field ID_CATEGORIE_COMPTABLE in FOURNISSEUR. The table FOURNISSEUR contains the followins fields: [ID_FOURNISSEUR, TYPE, NOM, CODE, ID_ADRESSE, ID_ADRESSE_E, ARCHIVE, ORDRE, UE, ID_COMPTE_PCE, ID_MODE_REGLEMENT, TEL, FAX, MODIFICATION_DATE, ID_USER_COMMON_MODIFY, ID_USER_COMMON_CREATE, CREATION_DATE, ID_LANGUE, ID_DEVISE, RESPONSABLE, TEL_P, MAIL, INFOS, ID_COMPTE_PCE_CHARGE, ATTACHMENTS, NUMERO_TVA, SIRET]
	at org.openconcerto.sql.model.SQLTable.getField(SQLTable.java:953)
	at org.openconcerto.sql.element.BaseSQLComponent.getField(BaseSQLComponent.java:175)
	at org.openconcerto.sql.element.BaseSQLComponent.addView(BaseSQLComponent.java:275)
	at org.openconcerto.sql.element.BaseSQLComponent.addView(BaseSQLComponent.java:267)
	at org.openconcerto.erp.core.supplychain.supplier.component.FournisseurSQLComponent.addViews(FournisseurSQLComponent.java:390)
	at org.openconcerto.sql.element.SQLComponent.uiInit(SQLComponent.java:209)
	at org.openconcerto.sql.view.EditPanel.<init>(EditPanel.java:204)
	... 43 more
J'ai désinstaller puis réinstaller openconcerto 1.5.1.
version java (build 1.8.0_151-b12)
Merci de votre intérêt.
Modifié en dernier par lodnexus le jeu. janv. 04, 2018 5:55 pm, modifié 1 fois.
jeu. janv. 04, 2018 2:05 pm
Merci de retélécharger la version 1.5.1, de l'installer et de mettre votre base de données à jour.
lodnexus
jeu. janv. 04, 2018 4:46 pm
j'ai désinstallé proprement openconcerto, puis installé la version 1.5.1. J'ai migré mon fichier OpenConcerto.h2.db dans le nouveau dossier, puis mis à jour ma base de donnée.
Je trouve toujours la même erreur au moment de créer un fournisseur.
	... 43 more
jeu. janv. 04, 2018 5:16 pm
Vous avez loupé l'étape "retélécharger la version 1.5.1".
lodnexus
jeu. janv. 04, 2018 5:32 pm
Effectivement, quand je dis que les gens ne savent plus lire attentivement... je tombe en plein dedans.
Je fais ca.
lodnexus
jeu. janv. 04, 2018 5:54 pm
Après
- suppression et réinstallation propre
- lancement de l'exécuteur configuration.exe,
- test de la connexion à la base de donnée - qui a créé un fichier base de donnée
- fermer configuration.exe
- remplacer le fichier OpenConcerto.h2.db dans le dossier
C:\Users\NameUtilisateur\AppData\Roaming\OpenConcerto\Data\DBData\
- Mise à niveau de la base de donnée dans l'onglet installation de configuration.exe
- lancement de l'application
Ca fonctionne !
Merci de votre patience et de votre réactivité !
