message d'erreur création de facture
gfrede
lun. avr. 17, 2017 4:26 pm
Voila mon probleme lors de la création de "vente"
Impossible d'accéder au résultat de SELECT max("SAISIE_VENTE_FACTURE_ELEMENT"."ORDRE")
FROM "OpenConcerto"."OpenConcerto49"."SAISIE_VENTE_FACTURE_ELEMENT"
in jdbc:h2:file:C:\Users\gfred\.java\ilm\sql-config\OpenConcerto\DBData/OpenConcerto
org.openconcerto.utils.ExceptionHandler:
at org.openconcerto.erp.core.sales.invoice.component.SaisieVenteFactureSQLComponent.commit(SaisieVenteFactureSQLComponent.java:1359)
at org.openconcerto.erp.core.sales.invoice.component.SaisieVenteFactureSQLComponent.insert(SaisieVenteFactureSQLComponent.java:1094)
at org.openconcerto.sql.element.BaseSQLComponent.insert(BaseSQLComponent.java:695)
at org.openconcerto.sql.view.EditPanel.ajouter(EditPanel.java:472)
at org.openconcerto.sql.view.EditPanel.actionPerformed(EditPanel.java:436)
Caused by: java.lang.IllegalStateException: Impossible d'accéder au résultat de SELECT max("SAISIE_VENTE_FACTURE_ELEMENT"."ORDRE")
at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:640)
at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:530)
at org.openconcerto.sql.model.SQLTable.getMaxOrder(SQLTable.java:1220)
at org.openconcerto.sql.view.list.RowValuesTableModel.commitData(RowValuesTableModel.java:298)
at org.openconcerto.sql.view.list.RowValuesTableModel.updateField(RowValuesTableModel.java:532)
at org.openconcerto.sql.view.list.RowValuesTableModel.updateField(RowValuesTableModel.java:547)
at org.openconcerto.sql.view.list.RowValuesTableModel.updateField(RowValuesTableModel.java:542)
at org.openconcerto.sql.view.list.RowValuesTable.updateField(RowValuesTable.java:270)
at org.openconcerto.erp.core.common.ui.AbstractArticleItemTable.updateField(AbstractArticleItemTable.java:157)
at org.openconcerto.erp.core.sales.invoice.component.SaisieVenteFactureSQLComponent.commit(SaisieVenteFactureSQLComponent.java:1266)
... 41 more
Caused by: java.sql.SQLException: second exec failed: File corrupted while reading record: "[8073] stream data key:480 pos:11 remaining:0". Possible solution: use the recovery tool; SQL statement:
FROM "OpenConcerto"."OpenConcerto49"."SAISIE_VENTE_FACTURE_ELEMENT" [90030-175]
at org.openconcerto.sql.model.SQLDataSource.executeTwice(SQLDataSource.java:965)
at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:608)
... 51 more
Caused by: org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "[8073] stream data key:480 pos:11 remaining:0". Possible solution: use the recovery tool; SQL statement:
at org.h2.index.PageDataNode.getNextPage(PageDataNode.java:231)
at org.h2.index.PageDataLeaf.getNextPage(PageDataLeaf.java:396)
at org.h2.index.PageDataCursor.nextRow(PageDataCursor.java:93)
at org.h2.index.IndexCursor.next(IndexCursor.java:274)
at org.h2.table.TableFilter.next(TableFilter.java:359)
at org.h2.command.dml.Select.queryGroup(Select.java:323)
at org.h2.command.dml.Select.queryWithoutCache(Select.java:627)
at org.h2.command.dml.Query.query(Query.java:314)
at org.h2.command.dml.Query.query(Query.java:284)
at org.h2.command.dml.Query.query(Query.java:36)
at org.h2.command.CommandContainer.query(CommandContainer.java:91)
at org.h2.command.Command.executeQuery(Command.java:196)
at org.h2.jdbc.JdbcStatement.executeInternal(JdbcStatement.java:177)
at org.openconcerto.sql.model.SQLDataSource$ExecutorThread.run(SQLDataSource.java:1157)"
Si quelque avait m'apportez une solution.
mar. avr. 18, 2017 2:57 pm
Le ficher de la base de données est corrompu.
gfrede
mar. avr. 18, 2017 3:53 pm
Bonjour Guillaume et merci
Mais que dois je faire?
Suppression/ré installation? ou il y a une autre solution?
mer. avr. 19, 2017 10:03 am
3 choix :
- restaurer le fichier depuis une sauvegarde
- faire réparer le fichier par la hotline
- effacer le fichier et donc tout reprendre de zéro.
