OLAP est en erreur
wawa_1
sam. janv. 21, 2017 3:20 pm
Bonjour, je vient de lancer OLAP Business et voila une erreur:
OLAP init error
Mondrian Error:Internal error: while parsing catalog file:C:/Users/utilisateur/AppData/Local/Temp/openconcerto2569619356526396511.xml
org.openconcerto.utils.ExceptionHandler: OLAP init error
at org.openconcerto.modules.reports.olap.OLAPPanel.reload(OLAPPanel.java:61)
at org.openconcerto.modules.reports.olap.OLAPPanel$1.actionPerformed(OLAPPanel.java:66)
Caused by: mondrian.olap.MondrianException: Mondrian Error:Internal error: while parsing catalog file:C:/Users/utilisateur/AppData/Local/Temp/openconcerto2569619356526396511.xml
at mondrian.resource.MondrianResource$_Def0.ex(MondrianResource.java:912)
at mondrian.olap.Util.newInternal(Util.java:2038)
at mondrian.olap.Util.newError(Util.java:2054)
at mondrian.rolap.RolapSchema.load(RolapSchema.java:436)
at mondrian.rolap.RolapSchema.<init>(RolapSchema.java:240)
at mondrian.rolap.RolapSchema.<init>(RolapSchema.java:60)
at mondrian.rolap.RolapSchema$Pool.get(RolapSchema.java:1121)
at mondrian.rolap.RolapSchema$Pool.get(RolapSchema.java:913)
at mondrian.rolap.RolapConnection.<init>(RolapConnection.java:151)
at mondrian.rolap.RolapConnection.<init>(RolapConnection.java:87)
at mondrian.olap.DriverManager.getConnection(DriverManager.java:112)
at mondrian.olap.DriverManager.getConnection(DriverManager.java:71)
at mondrian.olap4j.MondrianOlap4jConnection.<init>(MondrianOlap4jConnection.java:135)
at mondrian.olap4j.FactoryJdbc4Impl$MondrianOlap4jConnectionJdbc4.<init>(FactoryJdbc4Impl.java:369)
at mondrian.olap4j.FactoryJdbc4Impl.newConnection(FactoryJdbc4Impl.java:34)
at mondrian.olap4j.MondrianOlap4jDriver.connect(MondrianOlap4jDriver.java:119)
at java.sql.DriverManager.getConnection(Unknown Source)
at org.openconcerto.modules.reports.olap.OLAPPanel.reload(OLAPPanel.java:47)
... 37 more
Caused by: org.eigenbase.xom.XOMException: Document parse failed
at org.eigenbase.xom.wrappers.JaxpDOMParser.parseInputSource(Unknown Source)
at org.eigenbase.xom.wrappers.GenericDOMParser.parse(Unknown Source)
at mondrian.rolap.RolapSchema.load(RolapSchema.java:392)
... 52 more
Caused by: com.sun.org.apache.xerces.internal.impl.io.MalformedByteSequenceException: Octet 2 de la séquence UTF-8 à 3 octets non valide.
at com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.invalidByte(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.read(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.load(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.scanLiteral(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanAttributeValue(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanAttribute(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(Unknown Source)
... 55 more
Je n'arrive pas a comprendre le dysfonctionnement.
Merci pour votre aide précieuse.
Alex
dim. janv. 22, 2017 10:20 pm
On a déjà croisé ce bug une fois sur Mac, l'encodage des caractères accentués est à l'origine de se problème.
Corrigez votre fichier de configuration des hypercubes OLAP.
dim. avr. 23, 2017 2:07 pm
Je rencontre le même soucis, et effectivement les "é" sont mal encodés dans le fichier généré, je le corrige et en met une copie nommée openconcerto_catalog.xml dans le dossier configuration mais OpenConcerto ne le trouve pas et essaie de régénérer un fichier temporaire (re-buggé évidemment). Est ce bien dans le dossier Configuration que le fichier de configuration des hypercubes OLAP doit se trouver ??
dim. avr. 23, 2017 2:15 pm
De mémoire, dans le dossier de l'appli.
