message d'erreur
gfrede
jeu. janv. 05, 2017 4:58 pm
Je debute avec openconcerto.
Voici le message d'erreur : UncaughtException on thread Thread[main,5,main]
java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:h2:file:C:\Users\gfred\AppData\Roaming\OpenConcerto\Data\DBData/OpenConcerto;DATABASE_TO_UPPER=false
at org.openconcerto.erp.config.Gestion$2.uncaughtException(Gestion.java:196)
Caused by: java.lang.IllegalStateException: java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:h2:file:C:\Users\gfred\AppData\Roaming\OpenConcerto\Data\DBData/OpenConcerto;DATABASE_TO_UPPER=false
at org.openconcerto.sql.PropsConfiguration$Addable.get(PropsConfiguration.java:956)
at org.openconcerto.sql.PropsConfiguration.getDirectory(PropsConfiguration.java:1067)
at org.openconcerto.erp.config.Gestion.main(Gestion.java:307)
Caused by: java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:h2:file:C:\Users\gfred\AppData\Roaming\OpenConcerto\Data\DBData/OpenConcerto;DATABASE_TO_UPPER=false
at org.openconcerto.sql.PropsConfiguration$Addable.get(PropsConfiguration.java:952)
... 2 more
Caused by: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:h2:file:C:\Users\gfred\AppData\Roaming\OpenConcerto\Data\DBData/OpenConcerto;DATABASE_TO_UPPER=false
at org.openconcerto.sql.PropsConfiguration.createSystemRoot(PropsConfiguration.java:594)
at org.openconcerto.erp.config.ComptaPropsConfiguration.createSystemRoot(ComptaPropsConfiguration.java:723)
at org.openconcerto.sql.PropsConfiguration.getSystemRoot(PropsConfiguration.java:1006)
at org.openconcerto.sql.PropsConfiguration.createRoot(PropsConfiguration.java:380)
at org.openconcerto.sql.PropsConfiguration.getRoot(PropsConfiguration.java:996)
at org.openconcerto.erp.config.ComptaPropsConfiguration.createDirectory(ComptaPropsConfiguration.java:743)
at org.openconcerto.sql.PropsConfiguration$1.create(PropsConfiguration.java:238)
at org.openconcerto.sql.PropsConfiguration$Addable$1.call(PropsConfiguration.java:932)
at org.openconcerto.sql.PropsConfiguration$Addable.get(PropsConfiguration.java:950)
... 2 more
Caused by: org.h2.jdbc.JdbcSQLException: General error: "java.lang.RuntimeException: page[7906] data leaf table:0 T0 entries:6 parent:8583 keys:[9838, 9839, 9840, 9841, 9842, 9843] offsets:[1788, 1680, 1453, 1335, 1156, 1009] parent 8583 expected 6587" [50000-175]
at org.h2.engine.Database.openDatabase(Database.java:274)
... 32 more
Caused by: java.lang.RuntimeException: page[7906] data leaf table:0 T0 entries:6 parent:8583 keys:[9838, 9839, 9840, 9841, 9842, 9843] offsets:[1788, 1680, 1453, 1335, 1156, 1009] parent 8583 expected 6587
at org.h2.message.DbException.throwInternalError(DbException.java:231)
at org.h2.index.PageDataIndex.getPage(PageDataIndex.java:245)
at org.h2.index.PageDataNode.getRowCount(PageDataNode.java:288)
at org.h2.index.PageDataNode.getRowCount(PageDataNode.java:292)
at org.h2.index.PageDataIndex.<init>(PageDataIndex.java:88)
... 49 more
Si quelqu'un pouvait me dépanner svp.
Merci a vous
jeu. janv. 05, 2017 7:02 pm
Votre fichier de base de données est crashé (C:\Users\gfred\AppData\Roaming\OpenConcerto\Data\DBData),
restaurez depuis une sauvegarde.
