Pourtant la première fois j'ai mis en exécutable le fichier Openconcerto.sh et ça roulait depuis les nouvelles versions je n'arrive plus à rien.
Code : Tout sélectionner
Common is not a child of DBSystemRoot OpenConcerto1.1
	at org.openconcerto.erp.config.Gestion$1.run(Gestion.java:248)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:641)
	at java.awt.EventQueue$1.run(EventQueue.java:602)
	at java.awt.EventQueue$1.run(EventQueue.java:600)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:611)
Caused by: org.openconcerto.sql.model.DBStructureItemNotFound: Common is not a child of DBSystemRoot OpenConcerto1.1
	at org.openconcerto.sql.model.DBStructureItem.getCheckedChild(DBStructureItem.java:87)
	at org.openconcerto.sql.model.DBSystemRoot.getRoot(DBSystemRoot.java:90)
	at org.openconcerto.sql.PropsConfiguration.createRoot(PropsConfiguration.java:295)
	at org.openconcerto.sql.PropsConfiguration.getRoot(PropsConfiguration.java:694)
	at org.openconcerto.sql.ui.ConnexionPanel.<init>(ConnexionPanel.java:132)
	at org.openconcerto.sql.ui.ConnexionPanel.<init>(ConnexionPanel.java:127)
	at org.openconcerto.sql.ui.ConnexionPanel.create(ConnexionPanel.java:97)
	at org.openconcerto.erp.action.NouvelleConnexionAction.createFrame(NouvelleConnexionAction.java:167)
	at org.openconcerto.erp.config.Gestion$1.run(Gestion.java:233)
	... 14 more
