alors que tout fonctionnait à merveille depuis plusieurs mois, je me retrouve avec un bug désagréable:
- Paiement > Factures fournisseurs impayées
- ouverture de la fenêtre adéquate contenant deux factures en attente
- clic sur une des factures et BOUM:
org.openconcerto.utils.ExceptionHandler: UncaughtException on thread Thread[AWT-EventQueue-1,6,main]
at org.openconcerto.erp.config.Gestion$2.uncaughtException(Gestion.java:194)
at java.awt.EventDispatchThread.processException(EventDispatchThread.java:264)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:256)
at org.openconcerto.erp.core.supplychain.supplier.ui.ListEcheanceFournRenderer.getTableCellRendererComponent(ListEcheanceFournRenderer.java:58)
at org.openconcerto.ui.table.AlternateTableCellRenderer.getTableCellRendererComponent(AlternateTableCellRenderer.java:178)
at javax.swing.JTable$AccessibleJTable.getAccessibleChild(JTable.java:7044)
at javax.swing.JTable$AccessibleJTable.getAccessibleAt(JTable.java:7431)
at javax.swing.JTable$AccessibleJTable.valueChanged(JTable.java:6946)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:184)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:164)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:211)
at javax.swing.DefaultListSelectionModel.changeSelection(DefaultListSelectionModel.java:405)
at javax.swing.DefaultListSelectionModel.changeSelection(DefaultListSelectionModel.java:415)
at javax.swing.DefaultListSelectionModel.setSelectionInterval(DefaultListSelectionModel.java:459)
at javax.swing.JTable.changeSelectionModel(JTable.java:2389)
at javax.swing.JTable.changeSelection(JTable.java:2458)
at javax.swing.plaf.basic.BasicTableUI$Handler.adjustSelection(BasicTableUI.java:1109)
at javax.swing.plaf.basic.BasicTableUI$Handler.mousePressedDND(BasicTableUI.java:1074)
at javax.swing.plaf.basic.BasicTableUI$Handler.mousePressed(BasicTableUI.java:1026)
at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:280)
at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:279)
at java.awt.Component.processMouseEvent(Component.java:6513)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3312)
at java.awt.Component.processEvent(Component.java:6281)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4872)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4698)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4489)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747)
at java.awt.EventQueue.access$300(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:706)
at java.awt.EventQueue$3.run(EventQueue.java:704)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:77)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:720)
at java.awt.EventQueue$4.run(EventQueue.java:718)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:717)
at org.GNOME.Accessibility.AtkWrapper$5.dispatchEvent(AtkWrapper.java:697)
... 5 more
du coup impossible d'enregistrer le règlement de ces factures sauf à passer par une saisie à la main, mais dans ce cas, il est impossible d'indiquer à openconcerto cette régularisation et la facture reste en suspend
j'ai essayé de regarder dans la base si certaines données différaient des factures équivalentes réglées les mois précédents sans soucis, mais sans succès
Auriez vous une idée de la cause de ce problème soudain et de la manière de le résoudre ?
