OpenConcerto 1.3 beta 2
Tirlian
sam. mars 23, 2013 8:41 am
A ben là je crois que rien ne va plus!! :)
Ajout de devis, factures, articles, etc... impossible!
Je copie/colle le message d'erreur
Already dead, cannot exec IFutureTask running {UpdateOneRunnable@13310841 /DEVIS/[68] on ITableModel@13220195 for /DEVIS/} for {UpdateQueue on ITableModel@13220195 for /DEVIS/}
	at org.openconcerto.erp.config.Gestion$1.uncaughtException(Gestion.java:115)
	at java.awt.EventDispatchThread.processException(EventDispatchThread.java:264)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:256)
Caused by: java.lang.IllegalStateException: Already dead, cannot exec IFutureTask running {UpdateOneRunnable@13310841 /DEVIS/[68] on ITableModel@13220195 for /DEVIS/} for {UpdateQueue on ITableModel@13220195 for /DEVIS/}
	at org.openconcerto.utils.SleepingQueue.add(SleepingQueue.java:94)
	at org.openconcerto.utils.SleepingQueue.put(SleepingQueue.java:76)
	at org.openconcerto.sql.view.list.UpdateQueue.put(UpdateQueue.java:152)
	at org.openconcerto.sql.view.list.UpdateQueue.rowModified(UpdateQueue.java:117)
	at org.openconcerto.sql.view.list.UpdateQueue$TableListener.tableModified(UpdateQueue.java:55)
	at org.openconcerto.sql.model.SQLTable.fireTableModified(SQLTable.java:1210)
	at org.openconcerto.sql.model.SQLTable.fireTableModified(SQLTable.java:1223)
	at org.openconcerto.sql.model.SQLTable.fire(SQLTable.java:1188)
	at org.openconcerto.sql.model.SQLRowValuesCluster.store(SQLRowValuesCluster.java:357)
	at org.openconcerto.sql.model.SQLRowValuesCluster.store(SQLRowValuesCluster.java:248)
	at org.openconcerto.sql.model.SQLRowValues.commit(SQLRowValues.java:1272)
	at org.openconcerto.sql.model.SQLRowValues.update(SQLRowValues.java:1230)
	at org.openconcerto.sql.model.SQLRowValues.update(SQLRowValues.java:1225)
	at org.openconcerto.sql.element.SQLElement$2.create(SQLElement.java:604)
	at org.openconcerto.sql.utils.SQLUtils$1.handle(SQLUtils.java:76)
	at org.openconcerto.sql.utils.SQLUtils$2.handle(SQLUtils.java:112)
	at org.openconcerto.sql.model.SQLDataSource.useConnection(SQLDataSource.java:707)
	at org.openconcerto.sql.utils.SQLUtils.executeAtomic(SQLUtils.java:93)
	at org.openconcerto.sql.utils.SQLUtils.executeAtomic(SQLUtils.java:73)
	at org.openconcerto.sql.element.SQLElement.archive(SQLElement.java:584)
	at org.openconcerto.sql.element.SQLElement.askArchive(SQLElement.java:1669)
	at org.openconcerto.sql.view.IListPanel.handleAction(IListPanel.java:491)
	at org.openconcerto.sql.view.ListeAddPanel.handleAction(ListeAddPanel.java:52)
	at org.openconcerto.sql.view.IListPanel.actionPerformed(IListPanel.java:415)
	at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
	at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
	at java.awt.Component.processMouseEvent(Component.java:6505)
	at javax.swing.JComponent.processMouseEvent(JComponent.java:3312)
	at java.awt.Component.processEvent(Component.java:6270)
	at java.awt.Container.processEvent(Container.java:2229)
	at java.awt.Component.dispatchEventImpl(Component.java:4861)
	at java.awt.Container.dispatchEventImpl(Container.java:2287)
	at java.awt.Component.dispatchEvent(Component.java:4687)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
	at java.awt.Container.dispatchEventImpl(Container.java:2273)
	at java.awt.Window.dispatchEventImpl(Window.java:2719)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:729)
	at java.awt.EventQueue$3.run(EventQueue.java:688)
	at java.awt.EventQueue$3.run(EventQueue.java:686)
	at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
	at java.awt.EventQueue$4.run(EventQueue.java:702)
	at java.awt.EventQueue$4.run(EventQueue.java:700)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:699)
	... 5 more
Il faut vraiment que je me réinstalle tout ça proprement. La version 1.2 pour le moment, seulement si le transfert des données se fera sans problème de la 1.2 vers la 1.3 lorsqu'elle sera prête.
Une procédure SVP? (même la suppression de ma société est impossible)
dim. mars 24, 2013 10:49 pm
Problèmes de jeunesse de la 1.3, normal pour une beta.
La 1.3 beta 3 sera plus sympathique avec vous.
Le passage de la 1.2 à la 1.3 se ferra comme toujours en passant par l'outil de configuration.
Merci pour vos retours.
DUBOIS
mar. mars 26, 2013 12:17 pm
Voilà , j'ai téléchargé une version plus
récente de openconcerto multi poste 1.3 beta et lors
de la mise à niveau de la base openconcerto , voici ce qui est signalé
Echec de mise à jour
For input string: "min VERSION	20120723-195145.233+0200"
	at org.openconcerto.erp.config.InstallationPanel$1$1.run(InstallationPanel.java:281)
Caused by: java.lang.NumberFormatException: For input string: "min VERSION	20120723-195145.233+0200"
	at java.lang.NumberFormatException.forInputString(Unknown Source)
	at java.lang.Integer.parseInt(Unknown Source)
	at org.openconcerto.sql.model.SQLTable.findMinID(SQLTable.java:461)
	at org.openconcerto.sql.model.SQLTable.fetchUndefID(SQLTable.java:429)
	at org.openconcerto.sql.model.SQLTable.getUndefinedID(SQLTable.java:1059)
	at org.openconcerto.sql.model.SQLTable.getUndefinedID(SQLTable.java:1053)
	at org.openconcerto.sql.model.SQLTable.getUndefinedID(SQLTable.java:1025)
	at org.openconcerto.sql.model.SQLSelect.getUndefWhere(SQLSelect.java:278)
	at org.openconcerto.sql.model.SQLSelect.asString(SQLSelect.java:214)
	at org.openconcerto.erp.config.InstallationPanel.updateVariablePaye(InstallationPanel.java:2125)
	at org.openconcerto.erp.config.InstallationPanel.access$1(InstallationPanel.java:2118)
	at org.openconcerto.erp.config.InstallationPanel$1$1.run(InstallationPanel.java:129)
je n'arrive pas à comprendre la signification : pouvez-vous m'aider?
sam. mars 30, 2013 11:49 am
Utilisez vous une version monoposte ou multiposte?
Votre table FWK_METADATA n'est pas correcte.
