Code source & eclipse
mar. mai 29, 2012 5:34 pm
Il manque les librairies dans votre classpath. (voir dossier lib)
anautilisateur
lun. juin 04, 2012 8:16 am
s.v.p
1-il m'affiche que Jopendocument comme base de données sous eclipse (et n'est pas openconcerto)
2-les exceptions :
org.jgrapht.graph.DirectedMultigraph.clone()Lorg/jgrapht/graph/AbstractBaseGraph;
	at org.openconcerto.erp.config.Gestion$1.uncaughtException(Gestion.java:121)
Caused by: java.lang.NoSuchMethodError: org.jgrapht.graph.DirectedMultigraph.clone()Lorg/jgrapht/graph/AbstractBaseGraph;
	at org.openconcerto.sql.model.graph.GraFFF.createKeep(GraFFF.java:57)
	at org.openconcerto.sql.model.graph.DatabaseGraph.cloneForFilterKeep(DatabaseGraph.java:711)
	at org.openconcerto.task.config.ComptaBasePropsConfiguration.createFilter(ComptaBasePropsConfiguration.java:135)
	at org.openconcerto.sql.PropsConfiguration.getFilter(PropsConfiguration.java:810)
	at org.openconcerto.sql.request.FilteredFillSQLRequest.getFilter(FilteredFillSQLRequest.java:67)
	at org.openconcerto.sql.request.FilteredFillSQLRequest.setFilterEnabled(FilteredFillSQLRequest.java:73)
	at org.openconcerto.sql.request.FilteredFillSQLRequest.<init>(FilteredFillSQLRequest.java:57)
	at org.openconcerto.sql.request.ComboSQLRequest.<init>(ComboSQLRequest.java:86)
	at org.openconcerto.sql.request.ComboSQLRequest.<init>(ComboSQLRequest.java:82)
	at org.openconcerto.sql.element.SQLElement.getComboRequest(SQLElement.java:865)
	at org.openconcerto.sql.ui.ConnexionPanel.<init>(ConnexionPanel.java:229)
	at org.openconcerto.sql.ui.ConnexionPanel.<init>(ConnexionPanel.java:127)
	at org.openconcerto.sql.ui.ConnexionPanel.create(ConnexionPanel.java:97)
	at org.openconcerto.erp.action.NouvelleConnexionAction.createFrame(NouvelleConnexionAction.java:216)
	at org.openconcerto.erp.config.Gestion$2.run(Gestion.java:252)
	at java.awt.EventQueue$1.run(Unknown Source)
comment faire pour éliminer ces exceptions ,,es qu'il faut mieux comprendre Jgrapht
merci de me rependre
cordialement
lun. juin 04, 2012 1:31 pm
Utilisez le projet eclipse tel que fourni dans le repository de google,
il inclut ce qu'il faut (librairies et réglages).
lirvine
jeu. déc. 27, 2012 9:22 am
après test de la derniere révision 67, suite au Checkout :
- le JNLP n'est pas présent
- problème sur la méthode add dans le Module Lead, LeadGroup
- et * Le type SQLResultSet doit implémenter la méthode abstraite héritée ResultSet.getObject(int, Class<T>)
*Le type SQLResultSet doit implémenter la méthode abstraite héritée ResultSet.getObject(String, Class<T>)
en rajoutant la lib JNLP pas de souci de ce coté.
mais les 2 autres persistes, testé en openjdk1.6, openjdk1.7, 1.6, 1.7 sur Indigo, Juno et Windows et Linux
apres plusieurs test les versions java n'étant plus natives sous linux hors les versions libres openjdk je pense qu'il y à un souci dessus.
Je me rabat donc sur Windows test en 1.7 sous Juno toujours les meme problemes.
je teste donc en 1.6 windows Juno et la les érreurs SQLResultSet ne sembles plus présentes.
Je continu sur ma lancé et me retrouve avec un probleme de charactere (utilisé vous l'unicode ou autre ?), je corrige et j'en suis la.
a priorie il y a plusieurs Main dans le programme et j'en ai donc essayé plusieurs mais la je suis un peu perdu n'étant pas du tout familier d'eclipse et de java.
j'ai essayé celui qui s'appelle Gestion mais il me fait une erreur de connection de base par jdbc sous postgresql.
Hors les Warnings il reste uniquement l'érreur sur la méthode add dans le Module Lead, LeadGroup.
quelqu'un peut-il m'aidé, je trouve pas le point d'entrée si on l'appel comme ca en java, ou me manque t'il des modifications a faire pour compiler ?
ven. déc. 28, 2012 3:58 pm
Si vous avez une erreur sur SQLResultSet c'est que vous n'utilisez PAS le JDK 6 de Sun/Oracle. :twisted:
Les modules commités sont en pour la version 1.2, votre checkout a récupéré la version 1.3b1!
Pour la 1.2, il faudra faire un checkout sur une revision antérieure.
lirvine
ven. déc. 28, 2012 5:39 pm
Ok je comprend mieux pour les modules.
je vais refaire des tests merci
