Pertes de toutes mes informations et saisies
mar. mai 15, 2018 4:09 pm
D'après votre capture vous avez le tiercé gagnant :
Java 7 obsolète
Java 8 pas à jour
OpenConcerto avec 3 versions de retard
Il est temps de se mettre à la page :)
GG001
ven. mai 18, 2018 4:40 pm
Bonjour tvans;
Et cela qu'est ce que cela veut dire ??**********************************
Logger logs: /home/chauvel/OpenConcerto/logs/chauvel-MEGA-BOOK-EX720-chauvel/OpenConcerto-%u-age%g.log
mai 15, 2018 4:13:27 PM org.openconcerto.sql.model.SQLDataSource setLoginTimeout
AVERTISSEMENT: Ignoring login timeout for jdbc:h2:file:/home/chauvel/.java/ilm/sql-config/OpenConcerto/DBData/OpenConcerto/mardi/OpenConcerto
mai 15, 2018 4:13:36 PM org.openconcerto.sql.model.DBSystemRoot setRootPathFromDS
AVERTISSEMENT: db default schema is PUBLIC and the schemas of DBSystemRoot OpenConcerto are empty ; the first created schema will become the default one
Mise à jour désactivées (fichier de configuration manquant)
Ip:file:/home/chauvel/.java/ilm/sql-config/OpenConcerto/DBData/OpenConcerto/mardi/
Init phase 1:15955ms
mai 15, 2018 4:13:39 PM org.openconcerto.ui.preferences.AbstractProps load
INFOS: /opt/openconcerto/./Configuration/Email.properties does not exist for org.openconcerto.ui.preferences.EmailProps@196fe0
INFOS: /home/chauvel/.java/ilm/sql-config/OpenConcerto/Email.properties does not exist for org.openconcerto.ui.preferences.EmailProps@196fe0
mai 15, 2018 4:13:39 PM org.openconcerto.erp.modules.ModuleManager addFactories
AVERTISSEMENT: Module factory directory not found: /opt/openconcerto/Modules
Init phase 2:1228ms
mai 15, 2018 4:14:05 PM org.openconcerto.sql.model.SQLTable findMinID
AVERTISSEMENT: The system property 'fwk_sql.debug.undefined_id' is deprecated, use the 'undefined ID policy' metadata
mai 15, 2018 4:14:05 PM org.openconcerto.sql.model.FieldMapper findStream
INFOS: Using ressource org/openconcerto/erp/config/fieldmapping.xml
Warning: no default directory stored for document output
Warning: no default directory stored for PFD output
org.openconcerto.erp.generationDoc.DocumentLocalStorageManager
Default document directory: '/home/chauvel/OpenConcerto/Votre Société-48' does not exist !!
Default PFD directory : '/home/chauvel/OpenConcerto/Votre Société-48' does not exist !!
Document directories:
'VenteComptoir' : '/home/chauvel/OpenConcerto/Votre Société-48/Saisies de ventes comptoir' does not exist !!
'Courrier' : '/home/chauvel/OpenConcerto/Votre Société-48/Commandes fournisseur' does not exist !!
'AvoirF' : '/home/chauvel/OpenConcerto/Votre Société-48/Factures d'avoir fournisseur' does not exist !!
'BonReception' : '/home/chauvel/OpenConcerto/Votre Société-48/Bons de réception' does not exist !!
'Journaux' : '/home/chauvel/OpenConcerto/Votre Société-48/Journaux' does not exist !!
'VenteFacture' : '/home/chauvel/OpenConcerto/Votre Société-48/Factures' does not exist !!
'BonLivraison' : '/home/chauvel/OpenConcerto/Votre Société-48/Bons de livraison' does not exist !!
'Relance' : '/home/chauvel/OpenConcerto/Votre Société-48/Relances clients' does not exist !!
'Devis' : '/home/chauvel/OpenConcerto/Votre Société-48/Devis' does not exist !!
'FichePaye' : '/home/chauvel/OpenConcerto/Votre Société-48/Fiche paye' does not exist !!
'FicheArticle' : '/home/chauvel/OpenConcerto/Votre Société-48/Fiche' does not exist !!
'Etat des charges' : '/home/chauvel/OpenConcerto/Votre Société-48/Etat des charges' does not exist !!
'Livre de paye' : '/home/chauvel/OpenConcerto/Votre Société-48/Livre paye' does not exist !!
'FactureFournisseur' : '/home/chauvel/OpenConcerto/Votre Société-48/Factures fournisseur' does not exist !!
'Commande' : '/home/chauvel/OpenConcerto/Votre Société-48/Commandes fournisseur' does not exist !!
'Balance' : '/home/chauvel/OpenConcerto/Votre Société-48/Balance' does not exist !!
'Avoir' : '/home/chauvel/OpenConcerto/Votre Société-48/Factures d'avoir' does not exist !!
'CommandeClient' : '/home/chauvel/OpenConcerto/Votre Société-48/Commandes clients' does not exist !!
'Grand Livre' : '/home/chauvel/OpenConcerto/Votre Société-48/Grand Livre' does not exist !!
PDF directories:
AbstractLocalTemplateProvider.getFileTemplate() failed for id:Grand Livre language:null type:null files:'/opt/openconcerto/Configuration/Template/Default/Grand Livre' '/opt/openconcerto/Configuration/Template/Default/Grand Livre.ods' '/opt/openconcerto/Configuration/Template/Default/Grand Livre.odt'
mai 15, 2018 4:14:06 PM org.openconcerto.erp.generationDoc.TemplateManager dump
AVERTISSEMENT: 'Grand Livre' : stream missing
AbstractLocalTemplateProvider.getFileTemplate() failed for id:Etat des charges language:null type:null files:'/opt/openconcerto/Configuration/Template/Default/Etat des charges' '/opt/openconcerto/Configuration/Template/Default/Etat des charges.ods' '/opt/openconcerto/Configuration/Template/Default/Etat des charges.odt'
AVERTISSEMENT: 'Etat des charges' : stream missing
AbstractLocalTemplateProvider.getFileTemplate() failed for id:Livre de paye language:null type:null files:'/opt/openconcerto/Configuration/Template/Default/Livre de paye' '/opt/openconcerto/Configuration/Template/Default/Livre de paye.ods' '/opt/openconcerto/Configuration/Template/Default/Livre de paye.odt'
AVERTISSEMENT: 'Livre de paye' : stream missing
AbstractLocalTemplateProvider.getFileTemplate() failed for id:Relance language:null type:null files:'/opt/openconcerto/Configuration/Template/Default/Relance' '/opt/openconcerto/Configuration/Template/Default/Relance.ods' '/opt/openconcerto/Configuration/Template/Default/Relance.odt'
AVERTISSEMENT: 'Relance' : stream missing
AbstractLocalTemplateProvider.getFileTemplate() failed for id:VenteComptoir language:null type:null files:'/opt/openconcerto/Configuration/Template/Default/VenteComptoir' '/opt/openconcerto/Configuration/Template/Default/VenteComptoir.ods' '/opt/openconcerto/Configuration/Template/Default/VenteComptoir.odt'
AVERTISSEMENT: 'VenteComptoir' : stream missing
mai 15, 2018 4:14:06 PM org.openconcerto.sql.model.SQLDataSource setLoginTimeout
AVERTISSEMENT: Ignoring login timeout for jdbc:h2:mem:
mai 15, 2018 4:14:06 PM org.openconcerto.sql.model.DBSystemRoot setRootPathFromDS
AVERTISSEMENT: db default schema is PUBLIC and the schemas of DBSystemRoot are empty ; the first created schema will become the default one
mai 15, 2018 4:14:07 PM org.openconcerto.ui.JDate <init>
AVERTISSEMENT: commitEachValidEdit ignored due to Java bug
SELECT "CLASSE_COMPTE"."ID", "CLASSE_COMPTE"."NOM", "CLASSE_COMPTE"."TYPE_NUMERO_COMPTE"
FROM "OpenConcerto"."OpenConcerto48"."CLASSE_COMPTE"
WHERE ("CLASSE_COMPTE"."ID" <> 1) AND ("CLASSE_COMPTE"."ARCHIVE" = 0)
ORDER BY "CLASSE_COMPTE"."TYPE_NUMERO_COMPTE"
/home/chauvel/.java/.userPrefs/org/openconcerto/erp/modules/_!'4!|w!n!(!!bw"z!(@!~w"y!'`!cw"x!'w=/_!'4!|w!n!$%!:g!3!#4!:!!u!$!!.g!x!#c!@w!1!$@!:w!y
QU' EST CE QUE c'est LES NOM DE DOSSIER ; il y en a 2 ---->
/home/chauvel/.java/.userPrefs/org/openconcerto/erp/modules/_!'4!|w!n!(!!bw"z!(@!~w"y!'`!cw"x!'w=/_!'4!|w!n!$%!:g!3!#4!:!!u!$!!.g!x!#c!@w!1!$@!:w!y/_!'4!|w!n!%8!c!"l!'4!@w"v!'4!}w"l!()!d!"v
Bon A+ GG
sam. mai 19, 2018 3:02 pm
Vous pouvez vider le dossier : /home/chauvel/.java/.userPrefs
GG001
mar. mai 22, 2018 9:48 am
Bonjour Guillaume;
J'ai OC sous Windows avec la même version (1.4.2) et Java 7.45.12
et cela marche toujours : je pense qu'il doit y avoir une mauvaise sauvegarde qui c'est produit :
c'est pour cela que je ne retrouve plus ma Société !!!
Je suis en train de supprimer toute les sauvegarde les --> .zip qui ne veulent pas s’ouvrir !!
Et je remettrai la dernière sauvegarde que j'arriverai a ouvrir et on verra bien si cela marche !!
Bon je vais essayer cela !!
A+ GG
GG001
mer. sept. 25, 2019 3:44 pm
Bonjour Guillaume;
Ou trouve t’ont de quoi faire monter OC de la version 1.4.2 a la version 1.6.2 , je cherche la supérieur et je ne trouve rien ds la directory ??
Mercie de me répondre !!
A+ GG
mer. sept. 25, 2019 9:34 pm
