Je n'arrive plus à faire fonctionné OC sur mon nouveau poste
Serap
lun. mai 23, 2011 1:37 pm
Logs 1.1 beta1 même soucis
file:Données/
23 mai 2011 15:35:37 org.openconcerto.b.a h
INFO: listening on 1394
23 mai 2011 15:35:37 org.openconcerto.b.a.al m
ATTENTION: db default schema is PUBLIC and the schemas of al OpenConcerto are empty ; the first created schema will become the default one
Init:1631
NouvelleConnexionAction.createFrame( ) doInBackground Thread[SwingWorker-pool-1-thread-1,5,main]
java.lang.Exception: Stack trace
	at java.lang.Thread.dumpStack(Thread.java:1249)
	at org.openconcerto.gestion.config.t.run(Unknown Source)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:642)
	at java.awt.EventQueue.access$000(EventQueue.java:85)
	at java.awt.EventQueue$1.run(EventQueue.java:603)
	at java.awt.EventQueue$1.run(EventQueue.java:601)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:612)
org.openconcerto.b.a.cM: Common is not a child of al OpenConcerto
	at org.openconcerto.b.a.bk.n(Unknown Source)
	at org.openconcerto.b.a.al.a(Unknown Source)
	at org.openconcerto.b.d.t(Unknown Source)
	at org.openconcerto.b.d.H(Unknown Source)
	at org.openconcerto.b.h.m.<init>(Unknown Source)
	at org.openconcerto.b.h.m.a(Unknown Source)
	at org.openconcerto.gestion.b.t.a(Unknown Source)
Init2:2379
lun. mai 23, 2011 3:21 pm
Votre fichier main.properties n'est pas correct ou est absent. Le log indique que le logiciel se connecte à une base embarquée (h2) vide
et pas à la base PostgreSQL.
